Leaking power steering
Old Jan 18, 2011 | 09:45 AM
donaldm's Avatar
donaldm
2000 ranger, have a power steering leak where the steering shaft meets the rack. I assume there's a rubber seal out. Question has anybody used a "stop leak" that worked to seal steering seals. Rangers uses mercon atf for there steering fluid. If stop leak wont work . . . can I buy just the seals ? thanks don
Old Jan 18, 2011 | 10:06 AM
powersmoked's Avatar
powersmoked
when I got my truck 3 years ago. the fluid was of an unkiwn gross, watery mess.......I used the turkey baster method and replaced the fluid with atf and lucus power steering stop leak.........it pretty much so stopped.......I have to add a small amount of fluid ever few months
Old Jan 18, 2011 | 11:40 AM
03 Maz B23's Avatar
03 Maz B23
Ford has two power steering systems. One with a reservoir and dipstick and threaded connections at rack. The newer design that has a clear container with sight marks on side at reservoir and connections at rack (without threaded connections) but with O rings and a retainer to secure hoses in place. I have the newer style and also had a leak. It appeared to be coming from high pressure hose where it connects to rack . It turned out the hose itself wasn't leaking but the O ring on the hose was the culprit along with corrosion inside the housing where the line is connected. If you have the newer style check with dealer for an O ring.
