Was checking to see if anyone knew if you can put 35's on 16x7 factory wheels. Dont want a wide tire, just the 35 height and I have little knowledge of tires. What would the tire size be? Thanks.
I have Ford factory 20's on my Ex after having 35/12.5/17 on and its alot better ride. The 20's are 34.4 height and I use 2" adapters/spacers for the difference in backspace.
Keep in mind that the 20" would be about a half inch or better taller, not mounted on the truck and that it only has 50lbs of air in it ( factory spec. ) for the Ex.
