Passenger mirror
Old Jan 17, 2011 | 08:25 AM
boaterbob's Avatar
boaterbob
Passenger mirror
Well this is what i had to dig out of the door to mount the mirror. The truck was already painted so i cut the rectangle hole with my drill and dremel wheel and finally drilled and worked it out. the problem is the rectangle hole is about 1/8 or so bigger then the rubber mounting pad. ? do they make a bigger pad or someone with a clever thought, Really don't want to mmess with the paint.
Old Jan 17, 2011 | 08:59 AM
56panelford's Avatar
56panelford
You could make a small plate from thin gauge stainless steel and glue it around the hole and slide the mirror arm through it.
