backpressure sensor
Old Mar 7, 2003 | 05:56 PM
tcarr's Avatar
tcarr
Exclamation backpressure sensor
I need help real quick. I need to clean the exhaust backpressure sensor out. I think its on the front of the motor, but not sure. My truck keeps giving me a service engine light at around 28psi of boost and then shuts boost down about 10-15 psi. Superchip told me to clean the sensor. Any help would be appreciated.
Old Mar 7, 2003 | 07:20 PM
psd tech's Avatar
psd tech
backpressure sensor
tcarr, its located at the right front of your engine by the high pressure oil resevoir. Its located at the top of a bracket where the pipe leads down to the right manifold. Clean the pipe, and the carbon from the sensor, but you still may need a sensor. I have seen a few go bad. Good Luck.
Old Mar 8, 2003 | 02:45 AM
The Diesel Dude's Avatar
The Diesel Dude
backpressure sensor
The sensors are prone to failure. Clean the pipe and buy a new one.
Old Mar 8, 2003 | 08:25 AM
tcarr's Avatar
tcarr
backpressure sensor
thanks guys, i'll try that
