2wd Twin I-Beam Torque Specs?
Doing the bushings on the front end of my '99 2wd again - and have misplaced the notes I had with torque specs for the front end.
Would anyone happen to know the torque specs for the twin I-beam and the radius arms?
(I have the rest from the ball joint thread.)
Thanks in advance for anyone who has this information.
Good post I couldn't find that info in my book. Can you leave the radius arm to axle together can pull the back down to replace the bushing without taking it out. I need to change mine ! I was thinking of using my ball joint tool. Big C clap with drivers and I also use old bearing races to get the right size. But I haven't ever done these bushings. Need to get caster.
2 nuts on top i believe are 1 1/16" one hold the spring in place the other holds the radius arm
i have a feeling that radius arm will not get enough swing with it attached to the ibeam still
let us know how u make out
FordFETruck
36
09-11-2013 07:09 PM
