2 stroke oil
Old Jan 14, 2011 | 03:57 PM
ozzy460's Avatar
ozzy460
2 stroke oil
anyone heard of running a mixture of 2 stroke oil in their diesel 2 make up 4 the loss of lub w r new fuel? is it true? any benifit? pros n cons?
Old Jan 14, 2011 | 04:21 PM
Talyn's Avatar
Talyn
I'ma put this the simplest way possible.
in a 2cycle engine. the fuel is the lubricant for the parts. for the crank and everything.
2cycle motors run REALLY hard.
They sometimes do better on wear than regular 4 stroke motors.
Now, lets take 2 stroke and put it into our fuel in a good mixture and reap the rewards.
It scored best bang for the buck in the fuel tests.
I use 1/4 qt per tank.
I mix a bit heavy but oh well.
I got ATF in there right now, which is kinda a no no, but i'd rather have lubricity than none. I'll pour in fresh motor oil if i have no 2cycle.
Problem with 2 cycle is that its sometimes hard to find a qt for 3 or 4 dollars.
they all want 6-8 dollars here in michigan.
Anyways.
2cycle is great.
Old Jan 14, 2011 | 04:39 PM
ozzy460's Avatar
ozzy460
haha awsome!!! id heard 1/2 quart. but ill try 1/4 quart per tank. i was hoping it was a good idea. i like it.
Old Jan 14, 2011 | 04:46 PM
Hussler's Avatar
Hussler
Here is a study done on the subject.
Comparison chart is at the very end ...
http://www.johnfjensen.com/Diesel_fu...itive_test.pdf
Old Jan 14, 2011 | 05:12 PM
Robbgt's Avatar
Robbgt
Wow, I feel like I'm getting ripped off running power service.... where do you buy that opti lube stuff?
EDIT: NVM, found there site. Guess it's not something sold locally..
Old Jan 14, 2011 | 07:29 PM
pjwoolw's Avatar
pjwoolw
About 1 oz per gallon is a pretty good base.
Old Jan 15, 2011 | 09:40 AM
ozzy460's Avatar
ozzy460
i can get the opti lube stuff rite at my local feed store. sweeeet!!!!
Old Jan 15, 2011 | 09:52 AM
Robbgt's Avatar
Robbgt
^ Lucky. I just called fleetpride, international and 1 other local place and no one's got it.
I just sent them an E-mail asking if they have a retailer in the area
Old Jan 15, 2011 | 10:07 AM
Desert Rancher's Avatar
Desert Rancher
Also consider that 2 cycle oil is made to be burned in an engine, so the combustion process is cleaner.
No so with other oils that have additives that don't burn so well, which can leave deposits.
Old Jan 15, 2011 | 10:59 AM
compaddict's Avatar
compaddict
I buy Redline Watercraft 2 cycle oil by the gallon and run one ounce per gallon.
Old Jan 15, 2011 | 11:37 AM
Talyn's Avatar
Talyn
I dont think the quality of the 2cycle oil matters. I buy the cheapest on the shelf. Seeing as I over add anyways.
But yes, 2cycle is made to be burned and really made to be slippery stuff.
Old Jan 15, 2011 | 11:46 AM
bearhugger's Avatar
bearhugger
I dont get as good mpg using the two cycle oil as i do the diesel clean, but i dont put but six oz per tank,anybody have this problem.
JIM
Diesel 724
30
Nov 3, 2014 07:45 PM
mudsmokinstroker
May 11, 2014 04:26 PM
90pioneer
May 8, 2011 09:00 PM
04scurs
Jan 25, 2011 04:22 PM
5X5MOOSE
16
Aug 25, 2009 05:41 PM
