4x4 problems
Old Jan 13, 2011 | 10:41 AM
monstergt26160's Avatar
monstergt26160
4x4 problems
I have a 2002 F-250. My problem is the front hubs. There plastic and hard to turn, is this normal? Also when the hubs are in auto and you turn the
selector to fourwheel drive it does not engage. It use to work, but now
it just quit. Please help. Thank you.
Old Jan 13, 2011 | 10:49 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
You may need to do this. LINK
Make sure you don't have a vacuum leak. When you lock the hubs, can you turn the front driveshaft by hand?
Old Jan 13, 2011 | 12:21 PM
clintbonnie's Avatar
clintbonnie
If you can't turn the drive shaft, that tells the transfer case is working and the problem is in the hubs somewhere... maybe like Rick says, a vacuum leak.. I just replaced my vacuum soleniod which fixed mine.. Try disconnecting the vacuum at the top of the vacuum tank at the fitting that goes downward towards the hub.. Turn the key on, (don't start) and see if you have vacuum at this fitting.. (your vacuum pump should be running continuely)
Are you defrosters working OK ?
Old Jan 13, 2011 | 12:26 PM
robs01f250's Avatar
robs01f250
Im going with a vacuum leak. Check at both hubs and see if the vacuum lines are attached. If they are attached there then trace the wires back to the vacuum solenoid on the passanger side inner fender. One of the lines will be broken/split somewhere
Old Jan 13, 2011 | 12:42 PM
riverrat41's Avatar
riverrat41
I had to change my vac pump solonoid to get mine to work back a few years.Changed both tubes going to the hubs,greased inner hubs(per Guzzle) and it ended up being a dead solonoid
Old Jan 13, 2011 | 12:45 PM
robs01f250's Avatar
robs01f250
Well ok...but it is better to start with the cheap stuff first
Old Jan 13, 2011 | 02:10 PM
riverrat41's Avatar
riverrat41
These are all good suggestions.I was just throwing in my experiences with mine.
Old Jan 13, 2011 | 02:29 PM
monstergt26160
ok thanks for the input. I was thinking vacuum leak, put wasn't sure. Now is it normal
for the hubs to turn tight?
Old Jan 13, 2011 | 02:38 PM
riverrat41's Avatar
riverrat41
I think MillerFeed sent you Guzzles lube page.I bet if you do this they will be free again.They just need some love.
Old Jan 13, 2011 | 07:40 PM
monstergt26160
thanks again you guys for all your help.
Old Jan 14, 2011 | 08:17 PM
clintbonnie
Be sure to report back on what fixes your problems..
