Alternator Issue
Old Jan 12, 2011 | 07:05 PM
hndacr's Avatar
hndacr
Alternator Issue
Recently my truck alternator has been acting up. Sometimes at idle I am only getting 11.5V. Somedays at freeway speeds I get 12-12.5 others I get up to 13.9. My batts are 11 months old. I stopped at the parts store and they tested the alt for me tonight and the tested indicated a failed diode. I am assuming I have to replace the whole thing, is that correct? Can anyone tell me where to buy the OEM alt for the best price. Should I stick with the stock 110 amp or step up to a larger OEM alternator? In the truck I run a scangauge, A pillar pod of three guages, P3 brake controller, in dash navi system, and I have the factory inverter setup that comes on many newer Ford vehicles.
Thank You
Old Jan 12, 2011 | 07:07 PM
gearloose1's Avatar
gearloose1
The best place to get it was partsguyed.com but he is out sick.
Check the price from there, and then go get a Ford OEM alternator that is the identical PN for you truck -- not an also fit.
You save a few bucks with a Ford reman, but it is worth it.
Do not get a car grade alternator.
