Blinking Air bag light
Old Jan 7, 2003 | 03:56 PM
steve83's Avatar
steve83
Old Jan 9, 2003 | 12:19 PM
1bad65's Avatar
1bad65
Hey All,
Was hoping that someone could help me with a problem on my 96 F150. This morning the air bag light began blinking. I noticed what appears to be a code 4 blinks pause and then 1 blink. What does this mean?? Any help will be highly appreciated.
Old Jan 9, 2003 | 05:27 PM
steve83's Avatar
steve83
I posted some info on the airbag a few weeks ago. Have you searched for it? It could be in '87-96, Big Bronco, or Electrical.
Old Jan 10, 2003 | 10:56 AM
1bad65's Avatar
1bad65
Thanks for the reply I looked on several of the forums and didn't find anything. Found several people with different codes but no code 41. Any further assistance would be appreciated.
Old Jan 10, 2003 | 07:33 PM
jakegypsum's Avatar
jakegypsum
Sounds like the clockspring. It is the electrical link that connects the buttons on the steering wheel, (ie; cruise control, horn), plus the link to the airbag. Does the horn work sometimes? The airbag light on the dash is one of the first signs of this going. Good luck. Jake.
Old Jan 12, 2003 | 01:45 AM
steve83's Avatar
steve83
Code 41 is "RH Front Air Bag Sensor and Bracket Feed/Return Circuit Open" and 14 (just in case you're reading it backward) is "Front Air Bag Sensor and Bracket Circuit Shorted to Ground" (basically the same). That sensor is behind the grille at the top of the core support and the wiring runs across the core support to the L fender and back to the big firewall connector under the brake booster.
