Leaking
Old Jan 12, 2011 | 03:23 PM
hammer65's Avatar
hammer65
Leaking
Hey Guys:
I have a leak, and I cannot find where it is coming from.
At first I thought it might be the water pump. Leak is at center of truck, but back under the engine. I have checked and checked and can find no evidence that it is the pump.
The liquid on the ground is about the color of Gold antifreeze, although I am partially color blind. I could be red. It has a slight oily feel to it, when rubbed between the fingers.
It appears to be wet on the battery ground strap, just below the fuel drain. Aha it is fuel shut off, but it doesn't smell like fuel.
It is very wet along the length of the brake line that runs along the front cross member and drips from the lowest point.
Could it be a brake line leaking? Sorry for the long post, but this old man is stumped.
Any suggestions appreciated. Jim
Old Jan 12, 2011 | 04:12 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Jim, you may have to clean the area to get a better idea of where the leak is coming from. Hard to tell without looking. Good luck and let us know what you find.
