429/460 heads
429 Ford Heads D2VE-AA 429 460 NR Thunder Jet Lincoln heads will fit directly on my 429 block and what's their comparison to the ford racing scj heads. Also any tips on where I can find the motor mount for that block to slide in where my 351 5.8 sits, if they make them will it sit in the same spot and bolt up if I use a rear sump oil tank that's also low pro. Thanks guys
