Hood lock sticks
Old Mar 6, 2003 | 11:18 PM
dbarracuda's Avatar
dbarracuda
Hood lock sticks
I bought a hood lock today. It is one of the factory ones. I didn't notice this till i got home but the key will not turn to lock it when it is pushed. However the key will turn to lock it when it is pulled out. Any suggestions?
Thanks
David
Old Mar 7, 2003 | 12:10 AM
Mil1ion's Avatar
Mil1ion
Hood lock sticks
Push it in as far as possible.
Some of them are like that.
You might check the hood latch as well.
Old Mar 7, 2003 | 08:17 AM
dbarracuda's Avatar
dbarracuda
Hood lock sticks
I tried pushing it in but it seemed like i couldnt get it in far enough even though it was basically flush. I also tried pulling on the cable from the other end but that didnt help.
Thanks
david
Old Mar 7, 2003 | 01:51 PM
Mil1ion's Avatar
Mil1ion
Hood lock sticks
Sounds like the key doesn't work then.
Try unhooking the cable from the latch and try again.
Old Mar 7, 2003 | 02:33 PM
dbarracuda's Avatar
dbarracuda
Hood lock sticks
I believe that the key works because it will turn when the handle is pulled out just not when it is pushed in. Its like it hangs up on something when it is puched together. An i have tried unhooking the cable from the latch. I am going to take it to a lock smith and see if he can tell whats wrong.
David
Old Mar 7, 2003 | 05:28 PM
dbarracuda's Avatar
dbarracuda
Hood lock sticks
I got it. I talked to the locksmith and i decided to pull the tumbler and grind off part of the ridge that actually lokc it shut. It now works great.
Thanks
David
