98 Expy : rear door stuck closed..
Old Jan 11, 2011 | 10:54 PM
slaponte's Avatar
slaponte
Unhappy 98 Expy : rear door stuck closed..
First, the window stopped working. I opened the panel and found the wire that actuates the lock to be loose. Fixed.
Then a few weeks later the door itself got stuck closed and now won't open. Locks actuate and the window does open, but not the full door.
So, approach. If I go from the inside, can I remove the cover with the door closed (to access the lock mechanism)? If not, then, what??
Thanks.
Old Jan 12, 2011 | 05:44 AM
98EXPY 5-0's Avatar
98EXPY 5-0
Be sure to post if you are able to fix it. I will have a similar problem to work out soon. My hatch and window won't open, AND I have the added obstacle of having a cage behind the rear seat. So I have to find a way in from outside.
Old Jan 12, 2011 | 07:07 AM
johnpvb's Avatar
johnpvb
The lock cable has probably broken. You can pull off the panel even with the hatch closed and manually open the latch so you can get in there to replace the cable. There are separate but identical cables for the window and hatch latches.
This is a design weakness since the plastic ends of the cable sheath seem to break easily under stress.
There's a little challenge replacing the window cable since it appears to be build into the window hatch, but you can remove the hatch and carefully bend it open to remove the cable, then bend it back to replace it.
Good luck!
vgibbs
Aug 25, 2020 12:10 AM
SteveL53
Electrical Systems/Wiring
Jul 26, 2016 08:53 AM
devovino
Sep 30, 2015 07:48 PM
Derek1234
2009 - 2014 F150
Sep 4, 2015 12:53 AM
powerstroker100
Jul 10, 2015 01:18 PM
