what tranny fluid?
Old Jan 11, 2011 | 06:42 PM
96f350az's Avatar
96f350az
what tranny fluid?
my trannies at the shop after i detonated it getting rebuilt.
so my question(s)
which fluid should i use? im on a buget but i dont wana skimp. i cant have this happen again.
also any tips or tricks for re installing the tranny?
anyother input on this?
thanks for any advice you may have.
if needed trucks is a 96 f350 cc 460 e4od 4x4. thanks again
Old Jan 11, 2011 | 07:49 PM
96f350az's Avatar
96f350az
merc iv. im on it. owners manual here i come!!
Old Jan 12, 2011 | 06:47 AM
Lazy K's Avatar
Lazy K
Make sure you flush out the trans cooler and lines. Make sure the torque converter (new) is fully seated in the trans before you bolt the trans up.
I would think that the fluid originally for your trans was Dexron3/Mercron spec. However Ford now only supports Mercron V spec fluid so any fluid that meets or exceeds Mercron V should be fine. One that springs to mind is Mobil1 ATF.
