Questions on a new to me '92 F150
OK so I picked up a 1992 F150 XLT supercab 4x4
It didnt come with an owners manual, and I tried checking for
any info stickers on the Pillars ( drivers and passenger ), and looks like what was there has come off.
Is there any other place to check on the truck for info on what I have?
Motor is a 5.8 ltr. 351 Windsor
What typeTransmission - ?? where else can I look? ( It's an Automatic )
rear end - ??
I ran the VIN decoder and it showed the following info...
I have never owned a 4x4 and now I forget how the guy I bought it from told me how to switch over to it...
Is this the correct way?
Lock front hubs, shift to Neutral, change from 2H to 4H or 4L and your set?
What do you use 4H for?
What do you use 4L for?
I Will be getting Oil Changed.
should I get tranny fluid changed as well, so I know its done?
Anything else I should do?
Thanks in advance.
ROB
rear end - ??
Thanks in advance.
ROB
on
There should be an decal on the drivers door pillar, decode the trans and axle codes here... Ford Axle Code Chart .: Articles
That would be a 351w engine, neither the 351C or 351M made it past 1980 and the cleveland was never installed in trucks anyway.
Shifting in and out of 4Hi can be done on the fly, just lock the hubs and pull the lever or press the button when you need it. Shifting into 4Low must always be done with the vehicle stopped and the transmission in neutral. DO NOT drive on clear pavement with 4wd locked in or drivetrain damage will result, snow covered roads and offroad is OK. Note it is safe to drive straight forward on clear pavement in 4wd but turning is where problems start, the rear wheels turn a shorter radius than the front and that creates binding, so don't do it. The manual transfercase shift mechanisms always seize up and forcing them to move will usually break something, if yours doesn't move freely dismantle and lubricate it.
Be sure to excersise the 4x4 monthly, lock in the hubs, no need to pull the shifter, just lock in the hubs and drive around a couple miles. This is to get everything turning in the front axle to lubricate the bearings, seals etc.
Check your tranny fluid while engine running and warmed up to operating temps*
Check the level ofcourse and color, and smell it. If it is abit dark, smells burnt, flush it as soon as possible! Flush and filter!
I will be putting a walk around video up soon.
a strange thing I noticed yesterday ...
I was looking at the odometer while checking with the mile markers on the hwy. I was getting 1.8 miles between each mile marker.
What would cause that?
