head gaskets blown ?
Old Jan 11, 2011 | 12:54 PM
hott-rodd's Avatar
hott-rodd
My truck has been parked for a while, pending money to fix.
It pukes when run hard. I pressure tested with rad pump held 14 psi overnight.
when truck is running high rpm the pressure goes DOWN and holds, but when i let off the peddle the pressure goes UP higher than before i started. i repeated this until the pressure was 19 psi. Tester would not vent extra pressure.
Any idea what is going on? help
Old Jan 11, 2011 | 01:28 PM
gearloose1's Avatar
gearloose1
Test for exhaust in coolant with the chemical test kit.
Follow the TSB on head gasket tests...
Need multiple confirmation.
