I replaced my interior lights with hyper white leds and all my exterior lights are now leds with the exception of my headlight bulbs. All purchased from vleds also.
which leds did you use for your license plate lamps? i know they are 194s. I got the 5 led hyper white for them but they were to long so i put them in my outside cab lights. I just went to the chrome shop of houston a mile from my job and they have every led light i just got from v-led.
i did buy some smaller 6 led 194 bulbs that do fit in my license plate but im not sure how bright they will be, i will just have to wait until it gets dark to find out.
I also did my maps, dome and cargo light. Happy with the results too.
I am curious to see how the brake lights turn out for you. I'd like to do the same. Do you think the 3in switchbacks will fit?
thanks for the reply. I seen those and wasnt to sure if they would fit. they one i have now seem to light up pretty good and they were only 5 bucks.
The switchbacks go in the front turn signals and yes the 3in should fit. my brother has them in his 08 f150.
The rear brake lights are just 3157's. If you do them make sure you buy the resisters to or you will get the "hyper flash" (when the blinkers blink really fast like a light it out). This is because the leds dont have the resistance the normal filament buld does.
