HOW MUCH HP
Old Jan 12, 2011 | 11:11 AM
fordtrkboy88's Avatar
fordtrkboy88
sorry new to the diesels , so diesels make more torque than horsepower ? i figured 445 cu. in. hp would be around 350
Old Jan 12, 2011 | 11:23 AM
Robbgt's Avatar
Robbgt
Yes, diesels generally make more torque than horsepower. Diesel engines have a long stroke, which equates to more rotational force on the crank and more torque. With some modifications, they'll get up to the 350 range, but not from the factory.
HP = Torque * RPM / 5,252. Because these engines generally run at lower RPM's, the HP number's arn't huge relative to the engine displacement.
Hope this helps some, jump on google for some more technical information if so desired
Robb
Old Jan 12, 2011 | 12:50 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Originally Posted by superduty4x4
I believe that was in 98 with the change to the SD Dave.
FWIW, my 96 is a CA model with split shot injectors- valve cover says 215 hp. My E99, with essentially the same setup (different turbo and IDM) said 250 on the valve cover.
Another important factor is the superduty came with an intercooler so factory could probably run a hotter tune.
Old Jan 12, 2011 | 12:59 PM
superduty4x4's Avatar
superduty4x4
Good point. Funny thing is... some of the E99 trucks (my old one included) said 250hp on the valve cover. Some E99's and the later trucks said 225hp. It seems like Ford/Navistar just liked to play around with the number they put on there to make people wonder.
Old Jan 12, 2011 | 01:01 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Could be for different emissions requirements for the year. Like the OBS has a cat but the superduty didn't.
Old Jan 12, 2011 | 01:15 PM
superduty4x4
My E99 had a cat OEM...
Old Jan 12, 2011 | 03:27 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Good old Ford never know what or why they do stuff.
Old Jan 12, 2011 | 03:44 PM
superduty4x4
Isn't that the truth! When I had my 99 one of the doors got smashed in by someone and I put a new door on it. Even though all the holes for everything were identical, the bolts used to hold the speaker into the door were larger on the new door. WTF is that about? They didn't have anything better to do than that between model years?
Old Jan 12, 2011 | 03:51 PM
chicagodragon's Avatar
chicagodragon
Ran out of drill bits had to go bigger
Old Jan 12, 2011 | 04:22 PM
superduty4x4
Either that or one of my doors was a Monday or Friday build
Old Jan 12, 2011 | 06:18 PM
chicagodragon
Its a metric door
Old Jan 12, 2011 | 07:52 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Was that there reason when they had some engines bored to big for the pistons, they grabbed the metric bore drill? LOL.
ebbtide357
Sep 8, 2009 08:47 PM
powerstroke1997
58
Jan 22, 2008 05:50 AM
jacktownfireman
Dec 3, 2007 07:55 AM
sequim
Jul 22, 2005 07:59 AM
lmick
Feb 20, 2005 03:15 PM
