That darn engine light. "P1445", says the dude at AutoZone. Call Ford parts - $210 for the whole assembly, which includes the purge valve and sensor, and hoses all assembled into one "assembly". Nope, we don't sell just the purge valve or just the sensor. Okay. On line search, and success! Purge valve $36, sensor $19. They arrive, valve broken, send back, finally a good one arrives. Hmm. Hoses cracked and deteriorated. The hose that goes from the valve to the canister is larger on one end than on the other. Autozone: "...we don't have that." Ford Parts: "...we only sell the whole assembly for $210". Back to the store, spend almost an hour playing with two different sizes of hose and male to male connectors to make it work. Finally got everything together, spend about 30 minutes putting it together and installing. Hook battery back up and engine light is gone. Sweet.
Here's the problem. Now engine sort of "skips" in idle. It wasn't doing that before. Now it is.
Are we supposed to guess as to what you are working on?
Don't get too excited about the CEL being out. It's supposed to reset when the battery is disconnected. It then takes two consecutive failures of the OBDII monitor to turn it back on. Since evaporative emissions monitors have one of the most restrictive sets of prerequisites for test entry, it may be weeks or months before the previously-failed monitor to actually run.
Okay. It's been a couple of days and numerous starts. The CEL light has not returned. I think that was problem, as far as the code is concerned.
Check the reply "tomw" gave to the thread "How do I fix this." He gives some info originally provided by "Number Dummy" on parts availability.
Good luck on finding a Ford parts person who is willing to search for you.
I checked out the "tomw" reply you referred to. That's about what I did. It's been several days now and numerous starts and trips. The light has not returned. I think that took care of the problem, which was the engine light.
However, now the truck seems to run a little rough at idle. It's almost as if the timing is now a little off. It doesn't die, but it is not very pleasant to sit at a traffic light and the engine is sort of "pulsing" from a lower RPM to a higher RPM and back to lower, and back to higher, etc.
If I hadn't just replaced the valve, sensor, and lines connecting them to the canister, I would think timing or spark plug or something else. But the engine ran perfectly fine before I did this and now it doesn't.
Igniter64 my canister is not totally together, Canister is on hose to the purge valve thing fom there ther is a partial vac hose < Where does that go to.
I'm not sure how close your truck is to mine, but on my truck, (Ford Ranger 4 cyl eng) from the canister you have a weird hose that goes to the silenoid then a small hose to the sensor and then a longer hose to the engine. Hopefully this link will take you to where you can see a picture of the sensor. It is black, and a wire plugs into it.
You can also do a search on the web for "purge flow sensor" for your truck and you should be able to find a picture of it on one of the auto parts sites.
