block heater KW
Old Jan 10, 2011 | 08:43 PM
gatorpsd's Avatar
gatorpsd
block heater KW
Was wondering what the KW is on a block heater. I have two trucks plugged in tonight. I know I can see a difference on the light bill when I have them plugged in.
Old Jan 10, 2011 | 08:46 PM
Ken_C's Avatar
Ken_C
last I heard they are 1000 watts so that would be one kilowatt-hour per hour you run it. mines on an x-10 controlled outlet so it only turns on certain times of day.
Old Jan 10, 2011 | 08:52 PM
gatorpsd's Avatar
gatorpsd
With two plugged in one outlet that puts me at 16.66 amps. border line tripping a breaker.
Old Jan 10, 2011 | 09:15 PM
FARM69's Avatar
FARM69
I'd have one plugged in with a lighted cord end so you can easily tell if the breaker tripped.
Old Jan 10, 2011 | 10:26 PM
PowerStroker94's Avatar
PowerStroker94
Not if your on a GE breaker.
Old Jan 10, 2011 | 10:57 PM
Midwest Dually's Avatar
Midwest Dually
You know thats really a good topic.. How much of a difference in the utility bill a person should expect with plugging their PS in!
Old Jan 10, 2011 | 11:16 PM
Higgy's Avatar
Higgy
my girl says our electric bill only runs about 20 bucks more a month during the few plug in months. But I dont go to work until 1 so i can plug in for a couple hours before i leave.
i have thought about building a little cart equipped with a solar panel, a couple of batteries, and an inverter for this task, but it seems that it would take a few years to pay for itself. Would be cool though.
Old Jan 11, 2011 | 01:40 AM
madpogue's Avatar
madpogue
Only you can know that. Look at your electric bill and figure out what the per kWh cost is. Since the heater draws exactly 1 kW, as said, it draws 1 kWh for each hour it runs. Here, it's about 15 cents / kWh, so running it for 3 hours is 45 cents. And it's a waste to run it more than about 3 hours before you start it up. A timer pays for itself within a week if you drive it every day.
Old Jan 11, 2011 | 07:26 AM
Ken_C's Avatar
Ken_C
I dont think actual watts would be exactly 1000. it would depend on how many actual volts its running at. home depot has a device called Kill-a-watt it plugs in and has a display that tells you all kinds of interesting information including actual watts and how much a device costs to operate. you can get it other places besides home depot. your money would be better spent on a timer though. no reason to leave the heater pluged in 24/7.
Old Jan 11, 2011 | 07:42 AM
Robbgt's Avatar
Robbgt
x3 on timer. Mine's on a separate "block heater" circuit in the breaker box. 20A w/ GFCI.
Timer. Intermatic. has a cover to keep snow and assorted animals out. think it was around $20ish at local hardware store
It's only rated to 15A, 1800W so would probably not want to run 2BH's off it, but 1 is fine.
Robb
Old Jan 11, 2011 | 09:54 AM
gatorpsd's Avatar
gatorpsd
GE are pretty good breaker not as good as Square D. Now a Federal breaker that is scary. I couldn't trip one if I tried.
Old Jan 11, 2011 | 12:09 PM
superduty4x4's Avatar
superduty4x4
Robb
I have a similar timer, a worthwhile investment IMO.
