Big Tires
Old Jan 10, 2011 | 08:29 PM
Floor-N-It's Avatar
Floor-N-It
Big Tires
Does putting bigger tires F350 help with the gas milage?
Old Jan 10, 2011 | 11:11 PM
DIYiT's Avatar
DIYiT
It can as long as you're primarily interested in highway RPM. If you're doing a lot of start & stop, you're going to loose some mpg due to the higher load on the engine to get the vehicle moving.
Old Jan 11, 2011 | 12:07 AM
jeremy2008's Avatar
jeremy2008
Not really it takes more to move those big tires then it would do to move stock size tires. If you wanted to go with narrow tires they help a little because there is less tire on the ground which creates less friction.
Old Jan 16, 2011 | 02:10 PM
TJDave's Avatar
TJDave
Taller: possibly, wider: definately not.
Fyrfyghtr
Dec 14, 2016 07:20 PM
betontheturtle
Mar 22, 2007 10:28 PM
tolvibman
Bronco II
Jul 3, 2002 05:25 PM
Nathan
Apr 11, 2001 02:33 PM
StrangeRanger
Mar 18, 2001 04:27 PM
