351w swap
Anyway, you'll need a V-8 radiator, engine perches, & flywheel. The bellhousing is the same.
Gas mileage means miles per gallon
- EFI is consistently more efficient than carbs, and over a much longer lifespan than a carb's. But you can't have a 1bbl AND a 4bbl on your engine - which is it? I get great mileage AND power from my EFI - you have to choose one.
Repairable - yes. Mine tells me which parts are having problems, and they're easy to get to, change, repair, or test. I have fewer parts - you have at least 2 jets; at least 1 needle; who knows how many adjusting screws, cams, pushrods, diaphragms, check *****, weights, rubber seals, brass seats, springs, levers, floats, butterfly valves, needle valves, & vacuum ports; all of which have to be correctly adjusted for the engine to run right under all conditions, and a slight vacuum leak or a little varnish will throw everything off. Mine will adapt to variations in sensors, or ignore a sensor that isn't sending a usable signal, and it adjusts itself constantly. It learns all the time, and adapts to how I drive to keep the engine running if at all possible. I've towed a trailer to a gas station as I ran out of gas turning 300 RPM.
Look thru a performance website or magazine and count how many kits/parts are available for your engine with a carb, and then how many are available for the same engine with EFI. Cold air is a good start, but the sky's the limit nowadays.
I bought my engine for $1100 with all the accessories, and everything on it is from the junkyard or the old engine, except the coil, cap & rotor, plugs & wires, voltage regulator, starter, belt, & A/C compressor. Any sensors I've swapped out are still straight from a junkyard, but in ~250,000 miles I haven't had to swap many if any. And mine still runs as well today (after ~80Kmi in the original truck, a wreck that broke both engine mounts, then ~250Kmi in my truck including who knows how many collisions & a full roll) as it did new. I put ~200mi per day on it, many towing, many doing 80mph, and I hit the trails every chance I get. (LOTS of fun last weekend!
)I'll never mess with a carb again, but if you prefer them, I wish you ALL the luck!
