Sponsored by: Auxito
97 f150 electrical issues, please help
Old Jan 10, 2011 | 01:29 PM
sfd906's Avatar
sfd906
Hi, I sold a friend a 97 f150 5.4 about a year and a half ago. He let it sit since then. Finally put it on the road today. Put a new battery in it, started right up and ran great. Changed the oil and while we were doing that, a chime type noise started coming from the bottom the dash area around the middle, it kinda sounds like an old dialup tone. Also a clicking noise behind the fuse box under the hood. When the truck is off and the key is removed from the ignition, the windows will work, the radio will still be on and the blower motor can be operated. Does anyone know what could cause this? I was thinking maybe a bad ignition switch, any other ideas? Thanks
Also the airbag light is on now
Old Jan 10, 2011 | 05:08 PM
phil6608's Avatar
phil6608
Don't know about the 97 ,but my 03 will do that.....until you open the door!
Old Jan 10, 2011 | 05:40 PM
sfd906's Avatar
sfd906
Too bad that's not the case here
Old Jan 10, 2011 | 11:26 PM
Dr. Rik's Avatar
Dr. Rik
electrical problem
Yea it sounds familure, I would suspect the "GEM" module, that is the only item that can bypass the ignition switch and will allow stuff to work while the key is off.
lwibby 95EB
Sep 28, 2010 05:53 PM
mark8881
1997 - 2003 F150
Oct 28, 2008 07:31 PM
Silver97
Dec 23, 2007 01:30 PM
97-F150-97
1997 - 2003 F150
16
May 28, 2007 05:52 PM
greenego
Apr 12, 2004 09:40 PM
