My $2000 powerstroke
Old Jan 10, 2011 | 02:24 PM
Scud Runner's Avatar
Scud Runner
Its definetly oil. But I swear I seen fuel as well earlier. Looks like its coming down the back passenger side.
Old Jan 10, 2011 | 02:29 PM
427 fordman's Avatar
427 fordman
Could be both. The drain hole from the valley is on the back pass. side and whatever is leaking will run down there.
Old Jan 10, 2011 | 02:36 PM
Copedawg's Avatar
Copedawg
You may have a small fuel leak. There is a ton of stuff in the valley that can leak fuel. Could even be a fuel pump (DOH!). Do you have a "Cali" model or a "Fed" (49 state)? I see you have a signature already but if you add you truck "spasifix" it will help us all out a lot.
Last edited by Copedawg; Jan 10, 2011 at 02:45 PM. Reason: add S to pasifix to make SPASIFIX (specifics)
Old Jan 10, 2011 | 02:39 PM
Copedawg's Avatar
Copedawg
Originally Posted by fordtrkboy88
buddy thats a hell of a deal and the paint job it looks perfect , im payn a total of 8 grand for mine , i had the transmission rebuilt at dealer , torque convertor and main pump started messin up , welcome to fte , ive only been here for a couple weeks and learned alot about the motor and the trans its a repair manual lol
Speaking of signatures???????????????????? hehehe
Old Jan 10, 2011 | 02:41 PM
Iallwork's Avatar
Iallwork
Had both leaking on mine. Pedestal o rings and fuel pump vent hole. Plus off topic tranny leak. Fixed them all. No leaks now.Ya ya ya. Knock on wood.
Old Jan 10, 2011 | 06:36 PM
Scud Runner
Thanks guys. I will check out the items you talked about this week. I sure hope its a cheap fix. This truck is killing me hahaha.
Old Jan 10, 2011 | 07:12 PM
Copedawg's Avatar
Copedawg
SCUDY BUDDY...this is your subconscious talking....signature is due
Old Jan 13, 2011 | 04:30 PM
focracer's Avatar
focracer
where did you happen to get your cab lights? I have three broken ones too, its like the bulbs melted through the orange cap
Old Jan 13, 2011 | 04:36 PM
fordpride's Avatar
fordpride
you can get a set of five from LMC Trucks.com for like 35 bucks or so
Old Jan 13, 2011 | 07:43 PM
F350-6's Avatar
F350-6
Nice looking truck.
Oil leaks in the valley are usually o-ring related. Bob is a sponsor here and can take care of you in the o-ring department. Replacement O-rings for Ford Diesel Engines
You just need to clean things up and figure out where the leak is coming from. That or get some dye and a black light and look for the leak that way. In the mean time, carry extra oil with you. Your fuel injectors run off of engine oil so the truck will run bad or stall if the oil gets too low.
Chris56ford
67
Jul 20, 2014 09:15 PM
duck fan
15
Jun 4, 2014 05:17 PM
Chris56ford
May 10, 2014 03:04 PM
Brown Falcon
18
Nov 10, 2011 06:29 PM
Talyn
22
Mar 9, 2011 12:46 PM
