ETC Location
Old Jan 10, 2011 | 06:44 AM
J Gutierrez's Avatar
J Gutierrez
ETC Location
Starts cold, won't start after I turn it off while it's hot, after cooling --- it starts right up, and runs very well. computer say's ETC sensor,
I can't find it ! 96 Ford powerstroke.
Old Jan 10, 2011 | 09:11 AM
riverrat41's Avatar
riverrat41
Bump.For help
Action4478's Avatar
Action4478
Most likely the IPR o ring. The small one on the end
Name:  IPR without edge.jpg
Talyn's Avatar
Talyn
That sounds like an IPR issue.
Old Jan 10, 2011 | 09:25 AM
makomark's Avatar
makomark
No ETC parameter in any of my reference data. Get the computer hooked up again and get the code, too, along with the sensor (PID) name.
Could also be ICP sensor or maybe EOT (engine oil temp) sensor.
Old Jan 10, 2011 | 09:32 AM
J Gutierrez
Thank you for your help, I will get back after I get more info.
Old Jan 10, 2011 | 09:33 AM
Talyn's Avatar
Talyn
What was the actual code that you got?
Old Jan 10, 2011 | 01:26 PM
J Gutierrez
ETC sensor
Thank you for your help, I have someone comming over to give me another read out, I will send all I get, so that maby you folks can
tell me what to do.
Old Jan 10, 2011 | 03:42 PM
Cuda_jim's Avatar
Cuda_jim
ETC or ECT?, the latter is Engine Coolant Temp sensor and can be the cause for a no-start condition....for gas engines. Our diesels do not have one.
As already stated: IPR o-rings.
When it starts up OK cold but has trouble or will not start when warm/hot it's almost always the IPR o-rings. The hot, thinner oil leaks past the IPR causing a hard/no start.
Old Jan 11, 2011 | 04:16 AM
J Gutierrez
ETC Location
Thank you so much, can you tell how to find this o ring thing ?
I must tell you, this is a great truck, I have put tires and 2 batt's
in it in 11 year's. It still run's like new, with over 100,000 on it.
If the Ford dealership knew there was NO ETC sensor in this trk,
why did they not say so ? and why did they sell me this sensor ?
Old Jan 11, 2011 | 08:08 AM
Action4478's Avatar
Action4478
International should have the O ring kit
IPR O-Ring Kit (for when IPR valve replacement is not required)
(Ford) F6TZ-9C977-AA
(International) 1825806C92
An updated part # for IH - IH Part # 9X-1484
Old Jan 11, 2011 | 08:12 AM
J Gutierrez
ETC Location
THANK YOU !!!!
Old Jan 11, 2011 | 08:44 AM
makomark's Avatar
makomark
We do have an EOT sensor (engine oil temp). If it has failed, it should set one of it's codes. The ECU should use default values if the sensor fails. Shouldn't cause a not start but may inhibit performance a bit if failed.
Old Jan 11, 2011 | 09:08 AM
J Gutierrez
ETC Location
There is nothing wrong with performance, run's great.
I will get another computer read-out and get the code's,
so Iam getting the right info to you.
Thanks
Old Jan 16, 2011 | 04:29 AM
J Gutierrez
ETC Location
I did another computer read - out --- reading has NOTHING on it.
we did it 2 times, just to make sure -- still nothing is commiung up.
still doing the same thing - however Iam going to do the IPR o-ring
thing you told me about. Can you tell me how to find it.
Thank You
