Idling problem figured out!
Old Jan 9, 2011 | 07:20 PM
Domestic_Nuwbee's Avatar
Domestic_Nuwbee
90 F250 w/ 91 5.0 HO
Hey guys....after all the questions, and snooping through others threads I finally narrowed down my idling issue. The galloping issue on cold start up which was my initial problem was due to my IAC. Yesterday I took apart the IAC and cleaned her all up, put her back on with new gasket. Galloping gone. I also performed seafoam treatment via brake booster line using 1/3 the can with a 20min wait. Got some good smoke, but nothing crazy. (92,000kms on motor) Safe to believe the motors in good shape. However, when i was having the galloping issue, I was also having high idle problem at "normal" operating temp. (1000rpm) So after seafoam, not only did my throttle response sky rocket, and motor felt stronger...my "normal" temp idle went up too! 1200-1500rpm. Frustration has set it at this point. SO today, i said f*** it, ran to lordco and picked up the Innova Equus Ford Digital Code Reader (#3145, came with book with all codes)for $33 came home and plugged her in. I got code 63 "throttle position failure" TPS. Turned key over with engine off, grabbed my volt meter, set it at 10V and back probed at the harness to TPS. My idle reading was 1.0v which is correct i believe. So outa interest, I had throttle wide open and got 8v ( should be between 5.0v-10.0V ) So this undoubfully leads me to believe my TPS is faulty. That...or throttle body is clogged up. Will be replacing TPS tomorrow regardless, and cleaning throttle body out.
I just wanted to say thanks to everyone for all the help and support, you guys have been great. Hopefully, this will help any of you other Newbies just like me with issues like this.
BTW... check engine light in cab flashes code too, didnt know that.
Old Jan 9, 2011 | 07:24 PM
Domestic_Nuwbee
ALSO...I got a "canister purge fault" (coffee can) code thrown at me....cant remember the number. Is that critical??
Old Jan 9, 2011 | 08:02 PM
rla2005's Avatar
rla2005
I have a hard time believing you were getting a TPS output over 5 VDC. The VREF signal is only a 5 VDC voltage. There is no way the output signal can be greater than the supply voltage.
DTC 63 indicates the TPS voltage is below 0.6 VDC during the KOEO test. If the code is read from COM it indicates the TPS voltage was intermittently below 0.6 VDC. I would believe your TPS is probably faulty, but no way it can generate an output signal greater than the supply voltage.
For reference: Ford Fuel Injection » Throttle Position Sensor (TPS)
Old Jan 9, 2011 | 08:31 PM
Domestic_Nuwbee
hmmmm, I must've read it wrong then. Thank you for pointing that out. Either way, I'm on the right track to success.
Old Jan 9, 2011 | 08:37 PM
Domestic_Nuwbee
my mistake 63 is TSP circuit fault, below minumum voltage. When indeed my voltage was there. Thanks for clearing that up RLA2005
Old Jan 9, 2011 | 10:49 PM
rla2005's Avatar
rla2005
Let us know how it turns out
87-XL-Squared
Feb 26, 2016 07:52 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Sep 23, 2014 06:36 AM
Domestic_Nuwbee
Apr 10, 2011 04:26 PM
quisp-n-quake
Sep 25, 2007 09:24 PM
jcstratt
1997 - 2003 F150
Jan 31, 2006 11:28 PM
