BRAKE PROPORTIONING VALVE Problem
Old Jan 9, 2011 | 07:04 PM
hootmon's Avatar
hootmon
Red face BRAKE PROPORTIONING VALVE Problem
I have a 77 F-150 PO had put a bolt on valve where switch was I got a new switch and found out why the bolt was there it leaks fluid out around switch I don't think fluid is supposed to be there inside seal is gone. I guess I need to replace valve . Does anyone know where to get a stock one or should I do the pull apart thing or maybe a after market thats adjustable from summit.
Old Jan 9, 2011 | 07:34 PM
HIO Silver's Avatar
HIO Silver
IIRC, a replacement is like $250 or something like that. I'd go with an adjustable unit (Wilwood, SSBC, MP Brakes, etc) if mine failed. Get one with the provision for the brake warning light or else that light will be on and staring at you all the time. An alternative is leave it unplugged but that's kinda hackish IMO.
Old Jan 9, 2011 | 09:03 PM
hootmon's Avatar
hootmon
found one at carolina classic trucks for 68.88
Old Jan 9, 2011 | 09:56 PM
nothercrash's Avatar
nothercrash
As to the original problem, you got it right. Bolt in that hole was to seal it up, and the fact that there was fluid in there at all means it was bad.
I have the bolt right now, works for me but whatever suits your build.
Old Jan 10, 2011 | 02:45 AM
mdr617's Avatar
mdr617
I had the same problem in my 79 f100, i got a new proportioning valve from broncograveyard.com and it works great soo far.
hayden01
Jul 26, 2016 03:18 PM
unibody62
May 31, 2015 09:13 PM
Thudpucker
1997 - 2003 F150
Dec 29, 2011 02:33 AM
Myfreeford
Jul 5, 2011 01:20 PM
cebru
Dec 2, 2004 08:38 AM
