no break lights !!!!!
Old Jan 9, 2011 | 05:49 PM
surreyboy's Avatar
surreyboy
hey every one , i have a problem with my break lights , i have none ! i have a 97 f250 & i clanged the rear bulbs & checked the fuses , nothing ! any help or advice would be greatly appreciated
thanx !
Old Jan 9, 2011 | 07:42 PM
riverrat41's Avatar
riverrat41
You have checked what I would.Bump Bump
Old Jan 9, 2011 | 07:47 PM
firemaster's Avatar
firemaster
Do they light up for anything else? Like running lights or turns? If not I'd check the wiring that goes from the frame at the rear bumper to the lights. If both lights are out I'd be checking for a ground wire. Worse case scenario pull the lights and ohm the wires to see.
Old Jan 9, 2011 | 08:19 PM
PaysonPSD's Avatar
PaysonPSD
There is a brake pedal position (BPP) switch mounted on the brake pedal lever that you should also check.
First Diagram 2001 - Should also be good for 1999 & 2000.
Second Diagram 2002-2003
RedBoat's Avatar
RedBoat
Rather Be Floatin
Did you check the switch on the break pedal?
EDIT: Damn Robin your fast
Old Jan 9, 2011 | 09:12 PM
firemaster's Avatar
firemaster
Robin's always on the ball! Just relized he said 97 don't know if that changes anything though.
Old Jan 9, 2011 | 09:17 PM
Tenn01PSD350's Avatar
Tenn01PSD350
thanx !
Well, I see not much has changed here.
I know this does not help him but I am sure the 99-03 PSD wiring diagram will not either.
Old Jan 9, 2011 | 09:44 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Here are the Exterior Lights Prints for your truck.
Looking at these prints it could easily be your hazard switch. I would check it. As well as the brake switch on the pedel.
File Type: pdf
File Type: pdf
Old Jan 9, 2011 | 09:47 PM
PaysonPSD's Avatar
PaysonPSD
But it might help a 99-03 owner who runs across this thread.
Old Jan 9, 2011 | 09:53 PM
Tenn01PSD350
Very true Robin. As always good info. Hope all is well with you and the truck, take care.
Deluxe06's Avatar
Deluxe06
4000 rounds a min
You go Robin
Old Jan 9, 2011 | 10:13 PM
PaysonPSD's Avatar
PaysonPSD
All's well Mike , and you take care out there.
Old Jan 13, 2011 | 11:13 AM
surreyboy's Avatar
surreyboy
hey guys , sorry , i just realized i posted this in the wrong year , i did state though that it was a 97 , but still i apologize .could one of the mods move this to the right place ? thanx
also , i changed my switch , so the only other thing would be the wiring ?? could i just run a ground & a positive to it for now ? its to freaking cold here to be chasing wires ?? thanx again to every one !
Old Jan 13, 2011 | 12:54 PM
chiefn10's Avatar
chiefn10
DOES YOUR TRUCK HAVE A BRAKE LIGHT RELAY? THE RELAY MAY HAVE GONE BAD IF IT HAS ONE.
Old Jan 13, 2011 | 02:40 PM
orng1's Avatar
orng1
I traced everything on my super duty. Found the switch at the pedal was bad. Replaced it in 5 min and has been good.
