HELP!!!!!!!!!!
Old Jan 8, 2011 | 08:25 PM
Clueless1979ford100's Avatar
Clueless1979ford100
HELP!!!!!!!!!!
Would it be diificult to put a 351 in a 1979 F100 that just blew up a 302? Are the motors drilled the same, etc. What, if any, modifications would I need? I would appreciate any input. Thanks
Old Jan 8, 2011 | 08:34 PM
79 f350ts's Avatar
79 f350ts
depends on what 351 your swapping, 351m, 351c,351w.
Old Jan 8, 2011 | 08:41 PM
merccougar93's Avatar
merccougar93
if its a windsor, its just a drop in deal, maybe some problems putting the headers back on, since the deck height is different. But a modified/cleveland would need some fab work and the bell pattern is different
Old Jan 8, 2011 | 08:52 PM
79 f350ts's Avatar
79 f350ts
bell patern is differen on the m , but not the c everything else on the c howeveer is different so some fabbing wold be required. as stated above 351w is the closest to a "bolt-in" swap
Old Jan 8, 2011 | 09:06 PM
merccougar93
i thought the c and m bell patterns were the same, but ive been wrong many times before
Old Jan 8, 2011 | 09:13 PM
79 f350ts's Avatar
79 f350ts
cleveland uses the smallblock pattern, m uses the 460/429 pattern not sure exactly why Ford did this though, maybe someone here can enlighten us while we wait to see what the OP actually has
