Clutch Problem
Old Jan 8, 2011 | 04:34 PM
mike02's Avatar
mike02
Clutch Problem
1994 F150 4.9L Mazda 5 speed........Clutch pedal goes to the floor and won't pop back up. I replaced the slave cylinder because it was leaking and went ahead and installed a new clutch kit. I bled the system out and still the same problem. I checked the master cylinder for leaking and it looks fine, just a little dampness inside the cab around the mount. Any thoughts?????
Old Jan 8, 2011 | 06:32 PM
1996 Redneck F150's Avatar
1996 Redneck F150
If the inside of your cab is "a little" damp, then your master cylinder is probably bad.
Old Jan 11, 2011 | 11:34 AM
will1311's Avatar
will1311
^^^^agreed. I just fixed a similar problem in my 93. not a lot of fluid leaking but when I disassembled my master, it was obvious that the cup was allowing fluid to pass by and not hold pressure.
Put in a new master and it fixed my issue.
