Fuel tank help!!
Old Jan 9, 2011 | 09:31 PM
juni88126's Avatar
juni88126
Anyone know were to find the pickup for the poly tanks I think i found one listed at oreillys but it is 320. I broke mine when i moved the cab on the frame.
Old Jan 9, 2011 | 10:00 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Technically, yes low pressure lift pump.
But, if you have an in tank pump, then you need two so you can eliminate the stock lift pump completely.
Otherwise you can only use the tank with the lift pump in it.
And you also have to have a return line provision, which is in the sending unit.
Remember my position on electric fuel pumps versus stock lift pumps is one or the other, not both.
0500757Arf
Feb 3, 2026 05:37 PM
servitium
13
Feb 18, 2016 04:18 PM
Ex-ChevyOwner
Oct 7, 2015 09:14 PM
FordIowan
Jun 18, 2015 12:39 PM
Wayne Waldrep
29
Jun 7, 2014 08:56 PM
