looking to upgrade lights
Old Jan 8, 2011 | 02:01 PM
michaeloac's Avatar
michaeloac
I am looking to upgrade my lights and need some advice on which brand you would reccomend. I have been looking at the sylvania ultra, but am not sure they are the best. I love my truck but the lights are not all that. Thanks for any suggestions in advance.
Old Jan 8, 2011 | 03:02 PM
juneau76's Avatar
juneau76
Do a search for it. That topic has been highly discussed on this forum and others. I believe that PIAA and Sylvania Silverstars get the most votes.
Old Jan 10, 2011 | 09:12 PM
sdpaulie's Avatar
sdpaulie
I just got 2 hid kits from DDM tuning in San Diego. Google search them. good deal on the kits
Old Jan 10, 2011 | 10:13 PM
FUZZYDP's Avatar
FUZZYDP
How do you like them?
Old Jan 10, 2011 | 11:04 PM
Jus2shy's Avatar
Jus2shy
I saw on another F150 forum where a guy actually retrofitted real HID projectors into the stock F150 housings. It ended up costing him between 600 to 800 bux in parts and a backup set of halogen headlights while having the retrofit done. After seeing the beam picture matching that of high end luxury cars without all the "Spill", I think that'st he route I would go. I think I may try my hand at using a dremel tool to put projectors into the stock housing and see how it comes out.
Now I can't remember if we're allowed to link to another forum or not, but I can't find as definitive of a comparison as this thread, and kudos to the individual who took the time to retrofit his truck to show these pictures: http://www.f150forum.com/f38/custom-...ons-too-76242/
Last edited by Jus2shy; Jan 10, 2011 at 11:07 PM. Reason: added link to another website
Old Jan 11, 2011 | 08:41 AM
04XLTRUNNER's Avatar
04XLTRUNNER
i put 10k hid in my factory light housing and they work great. I also have them in my fog lights. I dont need a lecture about how the factory housing is not designed for hids, i know this. but they perform great and look good doing it. I have ran HID in my trucks for the last 3 1/2 years and i will never go back to a regular halogen.
Old Jan 12, 2011 | 12:32 PM
sdpaulie's Avatar
sdpaulie
I also have the hids in my fogs and headlights I love them!
Old Jan 12, 2011 | 04:58 PM
michaeloac's Avatar
michaeloac
Pardon the ignorance but do the hid's just replace the oem bulb or do you have to do more mods?
Old Jan 12, 2011 | 05:02 PM
FUZZYDP's Avatar
FUZZYDP
I just installed DDM HID's in head/fogs. Work great so far. Have had HID's in last 2 F-150's over 200K miles with no issues. Great visibility. Won't get flashed if you adjust them right. No modifications to install these.
Old Jan 12, 2011 | 07:00 PM
michaeloac's Avatar
michaeloac
Hey fuzzy, do you have a part # for them? Thanks, Mike
Old Jan 12, 2011 | 07:58 PM
FUZZYDP's Avatar
FUZZYDP
<table border="0" cellpadding="0" cellspacing="0" width="600"> <tbody><tr> <td colspan="3"><table border="0" cellpadding="0" cellspacing="0" width="100%"> <tbody><tr> <td class="pp_subheading">Here ya go.
Order Items</td> </tr> </tbody></table> </td> </tr> <tr> <td colspan="3"><img border="0" height="10" width="1"></td> </tr> </tbody></table> <table border="1" cellpadding="0" cellspacing="0" width="600"> <tbody><tr> <td> <table border="0" cellpadding="2" cellspacing="1" width="100%"> <tbody><tr> <td class="tableheadingcolor" align="center" nowrap="nowrap">QTY</td> <td class="tableheadingcolor" align="left" nowrap="nowrap">Item Information</td> <td class="tableheadingcolor" align="center" nowrap="nowrap">Item Number</td> <td class="tableheadingcolor" align="center" nowrap="nowrap">Price</td> </tr> <tr bgcolor="#f2f2f2"> <td align="center" nowrap="nowrap" valign="top">1</td> <td align="left" valign="top">DDM HID Kit, 35W, H13 High / Low, 5000K
Bulb Color: 5000K
Bulb Type: H13 Hi/Lo (+$15.00)
Wattage: 35 Watt
</td> <td align="center" nowrap="nowrap" valign="top">DDM35W.H13HiLo.5000K</td> <td align="center" nowrap="nowrap" valign="top">$50.00</td> </tr> <tr bgcolor="#f2f2f2"> <td align="center" nowrap="nowrap" valign="top">1</td> <td align="left" valign="top">DDM HID Kit, 35W, H10, 5000K
Wattage: 35 Watt
Bulb Color: 5000K
Bulb Type: H10
</td> <td align="center" nowrap="nowrap" valign="top">DDM35W.H10.5000K</td> <td align="center" nowrap="nowrap" valign="top">$35.00</td> </tr> </tbody></table></td></tr> </tbody></table>
Old Jan 13, 2011 | 03:52 PM
michaeloac's Avatar
michaeloac
Thanks Fuzzy !!!!!
Old Jan 13, 2011 | 06:10 PM
FUZZYDP's Avatar
FUZZYDP
Originally Posted by michaeloac
Thanks Fuzzy !!!!!
Any time.
Old Jan 17, 2011 | 12:04 PM
04XLTRUNNER
There are a few more parts that come with an HID kit. First you have the actual HID itself. I replaces your oem bulb in the same location with no mods. Then you have a ballast. Its the box that provides the correct voltage to the hid. Your ballast plugs into your factory light plug from the truck, then the other wire on the ballast plugs the the HID bulb and that pretty much it. Some kits also have an extra ground wire like mine. And I also have an extra set of wire from the ballast the run the + and - on the battery with an inline fuse. That is what provide my ballast with power. The plug to the factory harness just tells it to turn on and off, also low and high beam.
I know it sounds confusing and the first time I installed them I was lost but after looking at where everything goes there is nothing to it. Takes maybe 10 minutes.
Sorry for the long post, but its the answer your looking for, hopefully.
Old Jan 17, 2011 | 04:57 PM
cullenkyla's Avatar
cullenkyla
Thank you for your inquiry. The following are the headlight replacement options for your vehicle. Unfortunately your fog lamp model # 9140 is only available in standard halogen at this time.
2010 FORD F150
High & low beam headlamp
H13 (9008)
H13ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H13XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
Please let us know if you have any additional questions.
