2000 V10 getting 7.5 MPG
#46
I had 1 brake that would only hang up after a hard stop like a quick light or off ramp. the only way I found it was to pull the caliper off. 1 of the pistons was cocked in the bore which a parts guy said was because the caliper mounting bracket's holes got egged out, which looked like my bracket. replaced the caliper bracket and caliper no more hanging up.
#49
krbdog, I was getting around 8mpgs. but like all my issues with this truck it is all sporadic. I did get a new cat yesterday thanks to Lou's Custom Exhaust a high flow bullet type.
something else that helped was seafoam in the vacuum lines to burn off the carbon from my two sporadic failing cops.
#51
#53
#54
I have an 2000 Excursion and I'm having some of the same problems... used to have tons of power and now not so much. The gas mileage has gone down from 14.5 to 12 on the highway. I've replaced MAF sensor, coil boots, new cat, and run about 5 different kinds of fuel system cleaner through it. I've also replaced the fuel pump and filter. The truck acts like it doesn't get enough fuel because it bogs down when i step on it and also it bogs down when I accelerate in low RPMs. Any ideas? My next try is fuel injectors
#55
#57
100% agree!Almost every truck built before 2006 seems to need a tune.Look at some of the NASTY afr's on stock trucks I found online.
http://i197.photobucket.com/albums/a...-F150-Dyno.jpg
http://i197.photobucket.com/albums/a...graph_0001.png
#60
IMO is "In my opinion" This is the best $300 I've ever spent on a vehicle
DiabloSport U7153 - DiabloSport Predator Flash Programmers - Application - SummitRacing.com
There is a tuner that is a sponser on the forum you can use him too.
