Well Performing 300
I finally got aggrivated at it and adjusted the timing, but the first time i did it, i set it too far retarded and it was even more of a pig and stalled when i backed it out of the driveway.
I advanced it some and now lets say it'll lay down a patch of rubber at least 60 ft long, and get crazy sideways if i stay on it.
And the engine really isn't modified much, stock 1bbl carb, some type of RV cam. 2.47-ish gears (according to my rear end ID tag.)
Stock Exhaust manifold with stock piping and cat (its about to be ditched.)
I await the funds to swap on a 2bbl carb and the EFI exhaust manifolds...then whoo boy, i might look into a little N20 and a 240 head swap, fully ported & polished....
Needless to say, I'm Very Pleased!
so can i advance timing too or won't this do anything will it do any thing at all for me? i have i beleive 3.08's. all stock
4x4hey PKUPMAN82 i live in Grant u know where that is?
By disconnecting the SPOUT connector and bumping the timing, and reconnecting the Spout plug, it should in theory have advanced the timing some.
But, then again, the computer might not like this and not respond to it too well...
HTH.
I yeah I know where its at I'm not home right now. I am in the US Marine Corps living in Okinawa Japan. Any ways yes you should be able to play with your timing but the comp. might protest a little bit. My suggestion would be to advance it out a little bit at a time just to see how far you can take it before it starts to ping or run rough. The only problem with advancing really far is it takes away from your low end torque that you need when the truck is loaded down. I would suggest installing a better flowing exhaust system ( Flowmaster 40 with 2.25 duals on mine) , cold air intake, and a hotter coil ( Accel HEI on mine). You could install headers but I heard the split manifold on the EFI 300s flow nearly as good as headers. More than likely your truck has 3.08 gears especially if it has a manual transmission.
It finally bit the dust, and i was getting extremely poor MPG with it.
It was running so rich that it looked like i was burning wood in the bed of my truck...black smoke everywhere.
The truck was run like that for quite awhile before i got it and solved the problem, albeit temporarily.
Guess the next thing to go is gutting the cat. If i had some extra pipe... i'd just get rid of it and have nothin' but the muffler.
Hopefully i get my hotrod back soon!
greatly appreciate it
I havn't toasted a valve yet, so I must still have good hearing. (Or is that NOT a danger with "too much" advance in the "BIG -6"??)
- Still, it would be nice to know where the timing SHOULD be set! And what if you drove a lot at say - 9,000' - it seems like there ought to be an upper limit....
You can probably find your emissions sticker here, but with a high-mileage carbed engine, you're probably better off setting the timing by vacuum gauge.
Its got a little clip that slips up inside it, pull this out and start the truck, if you've got a timing light then thats great. If you've got a vac guage then thats even better.
(Be sure you put that little plastic clip back, or you'll have heaps of trouble from the computer!)
With the vac guage i'd tune the timing for the most vaccum you could get... more power, and a more efficient engine all in one.
Timing light, thats just the usual.... I don't have one, so i dunno.
I timed mine by ear and disconnected the vac advance and plugged it..
Much better, it actually got a little better economy and didn't make that horrendous clattering sound these engines are known for.
Thats when i made the post about the truck laying rubber down for 60ft.
This thing is a wild machine, provided you do the modifications to it.
IF yours was a carbed engine, i wouldn't recommend running around without the vac advance, it hurts your fuel economy and part throttle response.
But since yours is EFI, then i'd just bump the timing up a few degrees...but be careful you don't get spark knock or ping....thats too much timing, and usually described as a clattering noise. (my problem, too much adv.)
Hope this helps
-Tim-
Would you set a LOW mileage (20k) engine with a vacuum? (It's only the truck that's 21 - legal drinking age!!!) As I said, I've been an "ear" man (and sometimes/usually timing light). I'll read up on using a vacuum.
On a new engine, I'd go with the recommended setting off the emissions sticker, assuming everything else is stock. If you have some aftermarket performance stuff on it, I don't know.
