hmmm
Old Jan 7, 2011 | 10:21 PM
blackmajikf100's Avatar
blackmajikf100
hmmm
could someone help me out here this is rather confuzzling to me had someone put sugar in my gas tank ended up rebuilding the whole motor flushing and baking the tank putting on an electric fuel pump and now with the new rods and lifters i randomly get one rocker not spitting oil but it changes to different rockers O.o some help here its got new top end and machined cam crank rings and bearings all the bearings are where they are supose to be and everything is done to fftts (ford factory trained tech specs)
Old Jan 8, 2011 | 07:24 AM
Alex from GA's Avatar
Alex from GA
If there's good oil pressure then there's a blockage somewhere in the oil system or rocker shafts. Good luck. Did the cam bearings get changed? That's where the oil pressure is taken from.
