Having trouble starting engine
Old Jan 7, 2011 | 06:46 PM
cparisi210's Avatar
cparisi210
Question Having trouble starting engine
I have been having some problems and I cant diagnose it exactly. When it began the engine would crank but not start up. I would wait 5 or 10 minutes and it would crank and eventually start up. This would happen like once a week. Most days it starts right up. Then today I was leaving work and there was no sign of any electric working in the vehicle. I opened the door and everything came back on. Then I turned the ignition and everything shut off. Tried ten times then called for a ride home. Hoping its a relay or module of some sort. Please help- I don't really even know where to start
Old Jan 7, 2011 | 07:43 PM
88n94's Avatar
88n94
The trouble you had today sounds like a loose or dirty battery cable connection or ground, or a bad cable. No speculation on your earlier problem.
