Sponsored by: Real Truck
Radio Removal tool?
Old Jan 7, 2011 | 11:14 AM
EMC V10 X's Avatar
EMC V10 X
Radio Removal tool?
Where in the heck could I find the radio removal tool for the 6 disc radio?
Old Jan 7, 2011 | 11:18 AM
DCaillouetJr's Avatar
DCaillouetJr
most auto parts stores they are cheap i usually use a metal hanger and make my own but goto almost any auto parts store and you should be able to buy one if not im sure if you goto a car audio shop they would loan you theirs...
Old Jan 7, 2011 | 11:19 AM
bubbasz1's Avatar
bubbasz1
Simple tool any good auto parts store will have it, two wires with little notches on the end bent in a U shape, goes in the holes in the front of the radio on each side.
Old Jan 7, 2011 | 11:25 AM
EMC V10 X's Avatar
EMC V10 X
Thanks! The truck is new to me and Its saying all 6 discs are stuck. I tried the remove power thing and it didnt work. Time to get a little more invasive!
Old Jan 7, 2011 | 11:37 AM
DCaillouetJr
www.Sonicelectronix.com find the radio you want there then compair to ebay your radio will more than likely not work again just try to rescue the cds
Old Jan 7, 2011 | 12:31 PM
function12's Avatar
function12
Walmart sells. You can also use a coat hanger. Bend them in a U shape. Insert in holes the press outward toward the windows.
Old Jan 7, 2011 | 02:12 PM
husker's Avatar
husker
The tool is around $5, so I'd try the coat hanger, but if that doesn't release it easily, go ahead and get the tool. I had pulled the radio in other Fords with the coat hanger/wire trick, but couldn't get mine to release until I bought the tool. It made the job easy.
Old Jan 18, 2011 | 06:22 AM
EMC V10 X's Avatar
EMC V10 X
It was actually above freezeing last yesterday and I actually FIXED it! one of the trays had hung up, I freed it and it worked perfectly after that.
Old Jan 18, 2011 | 07:25 AM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
Ive used large rivets, scratch awls, pocket screwdrivers. etc. anything small enough to go in there and pry over the release. Takes some wiggling but it will work. (for future reference)
Drwoods72
1997 - 2003 F150
Feb 17, 2017 04:21 PM
4dtruk
Aug 11, 2013 07:49 AM
MNBen
Dec 17, 2012 11:41 AM
jreid
Aerostar
Mar 9, 2003 11:04 PM
