Some old-school Ford guy just told me that if you ever have any problems starting your truck, you should replace the headlight dimmer switch. He says it works for him most of the time.
The funny thing is, he is not the type to pull my leg...
Wait a minute. How does a headlight dimmer cause a battery drain when it isn't powered up until the headlights are on? There seems to be no continuity with that fact.
The wiring harness in my '79 wrecker caught fire and burn up because of a bad dimmer switch..I dont go as far as to replace them but at least take a look at them / clean them up ...I find that it the mechinisim works hard you are better off replacing them..
Jon
I had nothing but problems with mine so I took it out and replaced it with a highbeam toggle switch. Then whwn the high beams are on so are the low beams. Lights up the road a lot better. It does not tale much to make the dimmers mess up or corrode.
When you have both High and Low beams watch your headlight connectors for overheating. If you are running the power thru your headlight switch you may encourage "Ford flashing headlight" syndrome.
Gene, I think he was pulling your leg on this one.
However, those dimmer switches cause all sorts of other lighting problems. Being located in the floorboard makes them susceptible to moisture. When mine started sticking a while back, I sprayed it down with WD-40, and it now works like new.
We were talking about having the high and low beams on at the same time. These old ford trucks only had one set on at a time. The increased heat on the bulbs when both beams are activated simultaneously can cause the plastic connectors to melt. It can also cause the metal connectors to lose their spring tension and come loose which causes a bad connection and more heat, which causes the connectors to loosen more, ...
The increased current flow thru the circuit breaker that is built into the headlight switch can cause it to break the contacts so the lights go out. When the breaker cools they come back on, then heat up and go back off. Just like a turn signal flasher...
I have a -78 Truck- ,that must be what its doin. lights workin great, then all at once they go nuts like your tryin to get the on commin traffic to stop. Have made people run like hell lol. But how would i fix that?
Usually all you have to do is replace the headlight switch.
Do not run driving lights or other high current devices off the headlight circuit. Use a relay with a inline breaker from the battery to power these devices. You casn turn the relay on with your headlight circuit.
Check for shorts also that could be causing a high current draw.
When your headlight circuit breaker is activated for the first time it seems like it takes a lot less current to activate it the next time, and on and on... So even if you were using additional lights or had a short, -get a new headlight switch.
