Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
06 Escape acting up
Old Jan 6, 2011 | 12:18 PM
packers90's Avatar
packers90
06 Escape acting up
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtvisited="1"> <!-- / icon and title --><!-- message -->
<!-- In 1st Post Ad --><TABLE border=0 width="100%" itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top width="100%" itxtvisited="1">My sister has a 2006 Escape. She was driving it home and it died. The alternator was fried, so she had it towed to a local shop where they proceeded to work on it. Later they informed us they dropped the front axel to get to the alternator. On the way home it started grinding from the front end and now has no brake pressure. Grinding gets louder the faster you go and while turning. Talked to the shop about it and one employee said that they had to replace the ball joint because it was shattered. Next employee said they broke the hub and had to replace it. Think it might be the ball joint needing oiled to stop the grinding but not sure. Maybe just bleeding the lines for the brake pressure problem. Just seeing if anyone has any other theories/solutions.
Thanks for your time
-John
</TD></TR></TBODY></TABLE>
Old Jan 6, 2011 | 08:59 PM
tonyford's Avatar
tonyford
Sounds like the local shop broke the vehicle. I would leave it there until they fix it the right way.
You or your sister did NOT bring the vehicle into this shop with that problem.
Be courteous and tell them that. You brought the vehicle there because of the alternator problem, that was it.
If they give you a hard time, tell them you are going to sue them unless the vehicle and front end is back to the way it was when you first brought it in. Don't pander them, come straight out in a courteous way tell them that you want the vehicle fixed at their expense.
Old Jan 6, 2011 | 10:44 PM
scott91370's Avatar
scott91370
Have you looked at the brakes? They shouldn't have taken them apart but it sounds like they may have and did not get them back together correctly.
senix
Modular V8 (4.6L, 5.4L)
Jan 3, 2009 03:04 PM
michael_d_h
Dec 31, 2008 03:22 PM
donny3369
Dec 3, 2008 08:13 PM
mrbs66
Nov 21, 2008 08:11 AM
J1MMY
28
Oct 1, 2008 03:42 PM
