Which oil pan?
Old Jan 6, 2011 | 11:58 AM
finneys98xj's Avatar
finneys98xj
Which oil pan?
Which oil pan do I need for our truck a front sump or rear? I ask because the 302 We are pulling has a split pan to clear the cross member in the car it is in.
Old Jan 6, 2011 | 04:28 PM
CougarJohn's Avatar
CougarJohn
What application? A 302 in what?
Old Jan 6, 2011 | 05:05 PM
60F100's Avatar
60F100
I have a Mustang 5.0 (I am told it is mid to late 90's) and it has a double sump. However I do believe they used the original FE mounts and it sits higher than it should. I don't know how much lower it would sit with the proper mounts. If it doesn't drop it anymore than a couple of inches you should be ok with the double sump.
Old Jan 6, 2011 | 05:57 PM
BobbyFord's Avatar
BobbyFord
302 trucks had front sump pans.
Old Jan 6, 2011 | 05:58 PM
finneys98xj
Sorry forgot to include its going in a 72 f-100. Comming out of a 79 ltd
Old Jan 6, 2011 | 06:12 PM
finneys98xj
Another question will a double sump work in ours truck 1972 f-100 2wd
