sending units
Old Mar 6, 2003 | 07:39 AM
Gwilkrrs's Avatar
Gwilkrrs
sending units
can i get the tank and sending unit for the mustang tank or does the sendind un it have to match the gauge? i havnt bought the gauges yet so i dont want to buy the sending unit if it wont work with afternarket gauges.
Old Mar 6, 2003 | 08:54 AM
GreatNorthWoods's Avatar
GreatNorthWoods
sending units
Gwilly,
Sending units and gauges have to match. There are three basic sending units in 12V negative ground and they are Ford/Chrysler (78-10 ohms resistance), GM (0-90 ohms resistance), and after market (240-33 ohms resistance). All Stewart Warner, most VDO, etc., use the 240-33 ohm gauges. If you use the Mustang sending unit just be sure the gauge you use is for a Ford. If you use an aftermarket gas gauge not specifically for a Ford, you will need to change the sending unit. I am using the 240-33 ohm sending unit in my original fuel tank and the corresponding aftermarket gauge.
