Clean white walls
Old Jan 5, 2011 | 09:43 PM
NVRAGN's Avatar
NVRAGN
Clean white walls
What is the best way to clean marks off white wall tires. Have some bad marks and they didn't seem to want to come off with a scrub brush.
Old Jan 5, 2011 | 09:45 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Westley's makes a good whitewall cleaner.I've also used Brillo soap pads.
Old Jan 5, 2011 | 10:10 PM
Kurt G.'s Avatar
Kurt G.
I don't know if they sell it to the public, at work we use "Rubber Prep" Its used to clean the surface of a tire when doing a flat repair. This cleaner helps remove the small particals that interfere with the bonding of a tire repair. IE making the patch stick to inside of tubeless tires. Hope this helps. Kurt G. Y-blocks rule.
Old Jan 5, 2011 | 10:21 PM
51PanelMan's Avatar
51PanelMan
I don't recommend Westley's. It'll break down the white rubber pretty fast. Overtime it'll crack and become brittle. Keep in mind that you might not be able to get the marks out completely if they had time to penetrate. However, the marks will get better over time with regular cleaning.
I use Coker's brand white wall cleaner. I follow the instructions and have had good results. Pre-wet the surface with water, spray the cleaner on the white walls, let them sit for up to 10 minutes, scrub with a brush and then rinse off with water.
I've kept the WWW clean on my 52 Panel and the 37 Airflow by using Coker's brand for several years.
Old Jan 5, 2011 | 10:29 PM
ibuzzard's Avatar
ibuzzard
Ilya,I will admit I've never owned a set of WWW's.I had used Westley's only to clean raised white letters on tires when we sold them years ago, to remove the blue protective coating.It worked great for that purpose,but I have to yield to the voice of experience.
Old Jan 5, 2011 | 10:37 PM
51PanelMan's Avatar
51PanelMan
No problem, Steve. I only speak from "facts"! TEE HEE
Using Westley's on small letters like you had is ok. Even using it once or twice on WWW should be ok. Prolonged use isn't recommended. Westley's has harsh chemicals that will do damage to the WWW over time.
Old Jan 6, 2011 | 12:28 AM
Mervy49's Avatar
Mervy49
I tried my wife's magic erasers, that she uses in the kithchen, on raised the white lettering on my tires and they worked great. These are the ones adverised on TV.
Old Jan 6, 2011 | 04:40 AM
jake08's Avatar
jake08
Ditto. No problems with drying or cracking yet. I just don't do the process too often.
Old Jan 6, 2011 | 06:32 AM
Steves55's Avatar
Steves55
Simple Green works for me.
Old Jan 6, 2011 | 06:59 AM
49fordpickumup's Avatar
49fordpickumup
I haven't had WW in twenty years, but Comet or Brillo pads did work. I missed the hee hee move to San Josey. Some will go to extremes to stay on FTE, HAHA, HOHO, HeeHee.
Old Jan 6, 2011 | 07:04 AM
petey shoes's Avatar
petey shoes
ilya hit the nail on the head. good advise. once they are clean, try using lexol vinylex, blue bottle, for a protective coating that will last and does not draw dirt like armour all. if you use this, go by directions. soak cloth with product, DO NOT spray on surface.
Old Jan 6, 2011 | 03:37 PM
fifty-two_f1's Avatar
fifty-two_f1
My grandpa used to work at a filling station in the 50s and he uses westlys and a grill brush
Old Jan 6, 2011 | 06:45 PM
KidShalene's Avatar
KidShalene
Comet power on a small scrub brush....always got almost anything out for me.
budsweeds
Dec 9, 2015 06:46 PM
Jag Red 54
21
Mar 2, 2014 06:19 PM
dockrocker
2004 - 2008 F150
Feb 28, 2009 06:44 PM
snipa
Jul 20, 2008 08:37 PM
mikesfordf1
Feb 14, 2005 08:15 AM
