high psr celinod i think ?
Old Jan 5, 2011 | 06:51 PM
ibuda63's Avatar
ibuda63
I HAVE A 96 7.3POWER STROKE I CANT FIND THE NAME AND OR PART I NEED. I GOT THIS PART ONCE BEFORE BUT DONT REMBER WHAT IT WAS CALLED. THIS PART GOES ON DRIVERS SIDE BACK OF THE HIGH PRESURE PUMP AND IS CONECTED TO THE ELETRIC WIRING HARNES OF FUEL SYSTEM WHEN WORKING IT ALOWES FUEL TO INJECTORS MABY IF I HAD A WIRING HARNES DIAGRAM I WOULD KNOW WHAT IT IS CALLED SO I CAN ORDER IT PLEASE HELP THANKS ibuda63.
Old Jan 5, 2011 | 07:10 PM
F350-6's Avatar
F350-6
Welcome to FTE. The thing on the back lower driver side of the high pressure oil pump is the IPR (Injection Pressure Regulator).
Are you sure that is your problem? Are you going to replace it or try and clean it first?
Old Jan 6, 2011 | 11:12 AM
ibuda63's Avatar
ibuda63
should of tried cleaning first one? this one /when putting this one in i sliped and fell on and the two wire conections one came loose and should be replaced? how or where can i get a picture of wiring dig or of ipr and thanks for your help ibuda63
Old Jan 6, 2011 | 11:41 AM
ozzy460's Avatar
ozzy460
go back a few pages in the posts. someone posted pics of the ipr n such when i was rebuilding my ipr n after i broke me icp senser.
