I did just find this
<table class="wikitable"><tbody><tr><td>351 CID Windsor V8</td> <td>1983–85</td> <td>150 hp (110 kW)</td> <td>280 lb·ft (380 N·m)</td> <td>2bbl</td></tr></tbody></table>5.8 L V8 1987 210 hp (160 kW) 305 lb·ft (414 N·m) 4-bbl.
The '87 engine is a "351 H.O." All 351's after 1985 were. The "High Output" version adds a 4 barrel carburetor, larger air cleaner, and a performance oriented "marine" camshaft. The fact that the '83 is a 4x4 will slow it down some too because of all the extra weight.
