1978 - 1996 Big Bronco
Normal TTB Alinging question
Old Jan 5, 2011 | 11:42 AM
79f100six's Avatar
79f100six
So i bought a 1993 bronco a couple months ago and the guy that had it before me put a 4 inch lift on it. But the front tires are wearing more on the outsides on both sides than the inside of the tires. Now ive checked the ball joints and tie rods the radius arm bushings but the pivot joints i havent checked yet but on the drop brackets for the pivot joints there are two holes and right now the axle is bolted to the upper ones i was wondering if i bolted the axle pivots to the lower ones if it would fix the tires wearing funny since it should make the tires more level and make them wear better.
Old Jan 5, 2011 | 12:01 PM
Kemicalburns's Avatar
Kemicalburns
leave things as they are and take the truck to an alignment shop. those lower holes are for a 6" lift and will cause more problems if they are used with the 4" lift springs.
