Aerostar Ford Aerostar
Air bag code 52
Old Jan 4, 2011 | 06:48 PM
DOUG5G's Avatar
DOUG5G
Air bag code 52
I have ingnored my flashing air bag lght for a while. Since my horn also quit working I knew it was the clockspring. I just replaced it with one from the junk yard. The horn now works but I am getting code 52. I found this page Ford Aerostar Air Bag Code 52 but it tells me troubleshoot around circuit 611 and 612. My factory CD doesn't even show these circuits. Any hints on troubleshooting this code?
Thanks
Doug
1993 3.0L
Old Jan 4, 2011 | 09:16 PM
DOUG5G's Avatar
DOUG5G
I did find the circuits on my factory CD. I was able to verify that they read open. I have not been been able to read the voltage. Hopefully tomorrow I will have an update.
Old Jan 5, 2011 | 02:14 PM
DOUG5G's Avatar
DOUG5G
$15 for new diagnostic module from the local salvage yard and she is fixed. It was the blue box with the fuse that blows!
Old Jan 5, 2011 | 04:01 PM
xlt4wd90's Avatar
xlt4wd90
Good work.
Aren't salvage yards wonderful?
Old Jan 6, 2011 | 08:22 AM
DOUG5G's Avatar
DOUG5G
Half way to work it started flashing code 52 again. Since the resistance check was good and I replaced the module I am lost at how to fix this. It has to work in order to pass the va state inspection. Anybody out there have any ideas?
Thanks
Doug
Old Jan 6, 2011 | 04:41 PM
96_4wdr's Avatar
96_4wdr
circuits 611 and 612 should have at least 16v after 40 secs engine run.
circuits pin 15 W/O and p23 P/O
if not the capacitors are shot or the thermal fuse is blown again.
suspect you have an intermittent short to chassis ground somewhere in wiring 611 or 612, insulation worn through on sheet metal or failing intermittent internal short sensor
Old Mar 18, 2012 | 06:53 PM
FordVARunner's Avatar
FordVARunner
what was the fix...
Doug,
I live in VA myself and need to pass inspection, what was your fix for the code 52 flashing airbag light.
Thx
Thanks
Doug
DOUG5G
1983 - 2012 Ranger & B-Series
27
Nov 25, 2014 03:49 PM
Gene W
Oct 29, 2013 10:03 AM
mediaman67
17
Feb 8, 2012 03:13 PM
ochesdoches
1997 - 2003 F150
Nov 9, 2011 01:32 PM
ehgeeray
Jun 6, 2010 07:34 PM
