1978 - 1996 Big Bronco
Codes
Old Mar 5, 2003 | 09:01 PM
Red_EB_Bronco's Avatar
Red_EB_Bronco
Codes
I pulled up the carpet in the rear bay and found this paper telling me all about my truck, but its all in codes and I want to ask you guys if you know anything. I found on the web site about the rear end codes saying my truck had the limited slip (H9) 3.55s
The Transmission has two codes (prefix E8TP) and (suffix GA)
What tranny do I have?
Old Mar 8, 2003 | 08:02 PM
moemeadors's Avatar
moemeadors
Codes
I am looking for the same info on my '87 EB.
My trans code in the door is "T" and Axle says "19" type "U" I can't find any cross reference material.
If you find something would you please pass it on?
Old Mar 8, 2003 | 10:45 PM
Red_EB_Bronco
Codes
If I find anything i'll let you know, anyway I know my tranny is the 3-speed non-OD I hate it, I will look in my door to see what the code is for you.
Old Mar 8, 2003 | 11:13 PM
Red_EB_Bronco
Codes
I found the codes for the rear pumpkin on this site
You have the posi-3.55s while I have the limited slip 3.55s
Regular
13-4.11
14-3.00
16-3.50
18-3.08
19-3.55
Limited Slip
H3-4.11
H4-3.00
H5-4.10
H6-3.50
H8-3.08
H9-3.55
Old Mar 9, 2003 | 11:31 AM
steve83's Avatar
steve83
Codes
"Posi" is short for "positraction", which is the GM name for limited slip. 19 is an "open" differential with 3.55s.
moe
"T" is the AOD transmission; a non-electronic automatic overdrive.
Old Mar 9, 2003 | 08:30 PM
Red_EB_Bronco
Codes
Sorry I was confused on the difference i'm only 17, anyway the code for my tranny is "K" if you could kindly tell me, thanks*
Old Mar 9, 2003 | 09:41 PM
steve83's Avatar
steve83
Codes
K is the C6; a mechanical non-OD automatic, widely considered to be among the strongest automatics ever built. It uses both vacuum and mechanical kickdowns. Early mech. kickdowns were pushrods - later ones (like yours, probably) are cables.
Learn to ID automatics by gasket.
Learn about differentials.
If you want a doc & a pdf that explain VINs and other codes, send me a real e-mail, but be prepared to recieve ~500K.
