Idling problem
Old Jan 1, 2011 | 08:59 PM
Ben82's Avatar
Ben82
Idling problem
I have a 91 f150 351 and auto trans
It almost always idles at 2000 rpms after i start the truck and after im driving around for a while it will sometimes drop down to the normal idle range.
If i unplug the air bypass valve it drops to around 500 rpms but i dont really like driving around like that because it likes to stall that way
What could be wrong and is this a common problem?
Thanks
Old Jan 1, 2011 | 11:40 PM
DBGrif91's Avatar
DBGrif91
Well it could be a bad IAC valve.
It could also be a vacuum leak. That's where I'd start looking. Carefully check the condition of all the rubber and plastic vac lines. Remember that the plastic lines can crack and break easily, and sometimes it's not easy to spot the breaks in them. Also keep in mind that, when it comes to rubber vac lines, they can be sealed when they're cold and then when they heat up, they expand and the cracks start leaking.
Old Jan 2, 2011 | 06:07 AM
mpriester's Avatar
mpriester
Check the tps as well.
Old Jan 2, 2011 | 09:55 PM
Ben82's Avatar
Ben82
I already had the iac valve replaced and that didnt help the problem and how do i check the tps sensor?
Old Jan 3, 2011 | 06:53 AM
Lazy K's Avatar
Lazy K
Ford Fuel Injection » Throttle Position Sensor (TPS) Here is a link on how to check the TPS.
