Overhead computer install
Old Jan 1, 2011 | 02:29 PM
true blue's Avatar
true blue
Is it possible to install a factory overhead computer in a truck that did not come with it? I miss having a reference for fuel economy and DTE.
If not, is there a product out there that will perform this function?
Old Jan 1, 2011 | 09:57 PM
true blue's Avatar
true blue
Anyone tried this? I guess I might as well be the first. All I need is a wiring diagram, parts and greenbacks!
Old Jan 1, 2011 | 10:37 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Here I can help you out with this, It is for a 2005 F250 PSD
File Type: pdf
Old Jan 1, 2011 | 10:53 PM
true blue's Avatar
true blue
Thanks! This looks like it covers the light but where do I connect to get the information needed to calculate fuel mileage and DTE?
Old Jan 1, 2011 | 11:03 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Let me see what I can find.
Old Jan 1, 2011 | 11:25 PM
Jbrown8988's Avatar
Jbrown8988
I always wondered this too...
Old Jan 1, 2011 | 11:33 PM
true blue's Avatar
true blue
Thanks. I assume it has to tie into the ECM / PCM. Maybe tie into the OBD2? I think it needs info from the fuel gauge. Calculating mileage is easy but you have to know how much fuel you have then know current economy to get DTE.
Old Jan 2, 2011 | 06:20 AM
spdmpo's Avatar
spdmpo
You do realize that overhead display is not known to be accurate right? Seems like a lot of work to have something that doesn't work well. And if you have a chip or programmer it's even worse. My calculator and trip odometer work pretty good though.
Old Jan 2, 2011 | 11:45 AM
bluescrew's Avatar
bluescrew
i bought a mirror off ebay with autodim,compass and temperature gauge off ebay.. love it
Old Jan 2, 2011 | 01:06 PM
jirwin's Avatar
jirwin
Do you remember where you got the mirror? Is it a pretty easy install? I saw sombody on here that turned the overhead into a gauge pod.
Old Jan 2, 2011 | 01:53 PM
bluescrew's Avatar
bluescrew
just search for GENTEX there is a lot of options on ebay
extremely easy install. i cant live without my autodim mirror....
here is a link.. this is what i have. http://cgi.ebay.com/ebaymotors/Gente...ht_3305wt_1165
you can get them with map lights built in.. but i didnt really need that feature.
im pretty sure you can get them with the back up camere hook up now, so that when you throw it in reverse its also a video monitor!
Old Jan 2, 2011 | 02:55 PM
jirwin's Avatar
jirwin
here is a link.. this is what i have. Gentex Auto Compass Temperature Mirror GENK21 GENK21A - eBay (item 130459072284 end time Jan-25-11 11:07:13 PST)
Thank you. camera is a cool option. have it in my other car.
Old Jan 2, 2011 | 03:02 PM
JonathanN's Avatar
JonathanN
If I'm right, it's all about harnesses... there's a plug in the passenger-side kick panel. I have/had the console in my truck and I wanted to install clearance lights. It'd be all plug and play, I just had to replace the harness that goes to the console and the light harness would plug right into that. I'm almost positive all you'd have to buy would be either a harness that goes to that plug, or a harness to replace the one you have now if you've got clearance lights. Get with Ed and he'll be able to set you up... I'm not 100% sure this will work, but I'm almost positive that's how it works because that's how it is on my truck.
Old Jan 3, 2011 | 07:05 AM
true blue's Avatar
true blue
. Yes I do realize those facts. I just want a reference. I am a data geek.
Old Jan 4, 2011 | 08:53 PM
N4TECguy's Avatar
N4TECguy
Buy a ScanGauge II or some other such tool (I don't know if AE/Terminator/etc have the ability to do MPG and DTE). The overhead is crap...inaccurate, and sometimes just plain breaks. The ScanGauge allows you track MPG, DTE, MAP, ATF, ICP, IPR, etc (though only 4 on the screen at once). It also splits MPG/DTE data into "this tank", "previous day", "today" (data goes to previous day after 9 hours of no data from computer) and "current trip" (resets after 3 mins of no computer data). It lets you calibrate the MPG data by allowing you to enter the amount of fuel you actually put into the tank at each fuel up, and it trims/adds to the collected data by a proportional amount. I will say though, it is not always accurate - I calibrated mine at 55mph cruise going back and forth to work, and a few in town runs, and it read 13MPG at 80MPH but actual was in 16-17 range. And it will pull codes off most cars but probably not the diesel.
http://www.scangauge.com/features/
