Please help
Old Dec 31, 2010 | 12:17 PM
fairlane999's Avatar
fairlane999
Please help
I have a93 f150 302 two wheel drive automatic that buck and jerks under low rpm when put under a load such As climbing a hill. I have replaced tsp map plugs wires cap button thermostat egr and EEC and not any improvement. Removed and cleaned injectors no help. But if you unplug the jumper that you use to set the timing with it does not do it. Help I'm lost and broke. Tony
Old Dec 31, 2010 | 01:09 PM
88n94's Avatar
88n94
Have you checked the timing with a timing light? I would add some fuel injector cleaner to the gas tank even though you cleaned the injectors.
Old Feb 1, 2011 | 12:44 PM
fairlane999
Thanks for the help. I put a used distributor in it and it runs like new. Thanks again.
